I’m trying to find a solution to controlling all wall instances of a certain type. As they are part of groups, I can not mass select them therefore I tried to select by specific type id. I would like to controll their base offset without opening up each group. This is how far I got. do you have any suggestions?
@sovitek False alarm. I mean it works on small scale with 3-4 groups in a test project, but when I tried on the one we’re working on with couple hundred groups, even if I filter them down from not having accessing duplicates and search for a specific name gives an error that you have to be in group edit mode to do any modifications to the groups. Which is also weird cause Dynamo does not execute until the group edit mode is on.
