Thank you very much
Really appreciate your help.
Thank you sir,
It worked for me!
HI Ernesto,
I was just trying your script in revit 2020 , doesnāt seem to be working
i am getting a warning for the path og the log image file, and more importantly, see iamge below. also canāt run it a second time without reoading the script ⦠and lastly, not sure what the āparametergorupā roll down menu is used for.
i know this is an old scrpt, but it could be very useful ⦠i would be thrilled for any suggestions.
take care, we too, are on lock down here in france ⦠best, Laurence
Hi Ernesto - solved the problem myself ⦠itās not a problem after all, itās just that āproject informationā, āsheetā parameters, and others i assume, do not allow for ātypeā project parameters, but the script loads them anyway by type, but doesnāt allow you to change them from inside Revit !!
solution: be sure to load instance parameters correctly
yeah, probably I should update it to a newer version⦠one of this days I will XD
