Insert CADLinks in views
Hi! I’m new to Dynamo and python. Now I’m tring to insert cadlinks in conrresponding views. I found this attached python script which work perfect with one cad to one view, but when I change it to do with multiple files this error appear “EOL while scanning single-quoted string”
Import DocumentManager and TransactionManager
app = uiapp.Application
Import RevitAPI
clr.AddReference("RevitAPI")
dataEnteringNode = IN
filePaths = IN[0]
views = UnwrapElement(IN[1])
viewsplaced=list()
options = DWGImportOptions()
options.AutoCorrectAlmostVHLines = True
options.ColorMode = ImportColorMode.BlackAndWhite
options.OrientToView = True
options.ThisViewOnly = True
options.VisibleLayersOnly = True
options.Unit = ImportUnit.Meter
options.Placement= ImportPlacement.Centered
linkedElem = clr.ReferenceElementId
for view in range(len(views)):
doc.Link(filePaths[view], options, views[view], linkedElem)
viewsplaced.append(views[view])
OUT = viewsplaced;
Hi @L_VADU,
Welcome to the forum.
It looks like you have an error with the filepaths but it’s hard to know without seing a screenshot.
If you don’t want to use a python script, there are custom nodes to link or import DWGs.
Thank you so much!!!
