Batch link DWGs in Drafting Views
I have corrected Python script to link two o more DWG.
Enjoy
#Copyright 2019							 ###
#by Marco Moscatelli 		feat Konrad	 ###
#Email: flytelli@gmail.com				 ###
app = uiapp.Application
# Import RevitAPI
clr.AddReference('RevitAPI')
dataEnteringNode = IN
filePaths = IN[0]
views = UnwrapElement(IN[1])
viewsplaced=list()
options = DWGImportOptions()
options.AutoCorrectAlmostVHLines = True
options.ColorMode = ImportColorMode.BlackAndWhite
options.OrientToView = True
options.ThisViewOnly = True
options.VisibleLayersOnly = True
options.CustomScale = 100
#options.Placement = Origin
LinkedElem = clr.Reference[ElementId]()
for view in range(len(views)):
	doc.Link(filePaths[view], options, views[view], LinkedElem)
	viewsplaced.append(views[view])
OUT = viewsplaced;
Great work @mmoscatelli :ok_hand:.
I’ve changed the category to Share, since you provided a working solution.
Thanks Martin,
I’m newbie. It’s my first post :grin:
Hi mmoscatelli :wink:
Thanks for providing this script :slight_smile: It works for one view, but what do I have to change to get it to work with multiple views?
It is my goal to link it f. ex. 5 DWG Files to 10 Views. When I generate an input list with 10 dwgs links (some of them doubled, because they are supposed to be linked on two views) and 10 views it does not work.
I get the following error:
Is the “LinkedElem = clr.ReferenceElementId” the problem? I never saw this one before…
Thanks and kind regards,
Jannis
