I have this list of dwg files and then i want to put this CAD files in sheets (Revit)
If i do this one by one, like by using File Path node, then it will work. (Paper space gets attached in sheet)
Each dwg file have 1 paperspace layout
But I have big list of CAD files.
app = uiapp.Application
# Import RevitAPI
clr.AddReference("RevitAPI")
dataEnteringNode = IN
filePath = IN[0]
view = UnwrapElement(IN[1])
options = DWGImportOptions()
options.AutoCorrectAlmostVHLines = True
options.ColorMode = ImportColorMode.BlackAndWhite
options.OrientToView = True
options.ThisViewOnly = True
options.VisibleLayersOnly = True
linkedElem = clr.Reference[ElementId]()
doc.Link(filePath, options, view, linkedElem)
OUT = filePath
Line 36 is this: doc.Link(filePath, options, view, linkedElem)
I have uploaded dyn file. Dynamo 2.0.2 and Orchid Package
sheet 3 - multiple files.dyn (18.8 KB)
