Input Order for Dynamo Player (2024 Civil 3D)
Hi @btillett,
When you select a graph in Dynamo Player, there’s an option in the display preferences (upper right corner) to sort the nodes alphabetically. If that is unchecked, then you should get the behavior you describe with nodes being sorted in the order that they were inserted into the graph.
