Input OOTB nodes not shown in Dynamo Player
Hello all,
I recently installed the version of Dynamo 2.0.1 in my computer and also retained Dynamo 1.3. Now the scripts created using 1.3 shows the inputs(selection, dropdown etc…) in the dynamo player correctly. However the scripts created in 2.0.1 doesn’t show up any of the input in the player.
Many of my scripts uses OOTB nodes from archilab - @Konrad_K_Sobon and Rhythm - @john_pierson, which was working well before and is now with the version 1.3 but not with the version 2.0.1.
some of the images showing the warnings
grafik
grafik
I have read through this post but no luck in finding a solution.
Could someone please advice me on this. Thanks.
Drop some sample files on here.
Sorry for the late reply. Here below are the files of both the versions.
Created with 1.3.dyn (3.6 KB)
Created with 2.0.1.dyn (5.4 KB)
@Raja
1
Oh my goodness, I feel so dumb now. Thanks a lot @fathygad. In Dynamo 1.3 the property of the node “Is Input” was by default turned on, so I always had in my mind only to turn off things which aren’t necessary. Its not the case with Dynamo 2.0 I see. Anyway good leason learnt today :slight_smile:
