@SeanP yep that works, it changes every space type to whichever index i type into the code block. I need to figure out how to adapt that so we can have it change to mulitple different space types depending on the rooms purpose.
Thatās good. If you go back to my Post #15, you only need to connect your Excel data (space type) to where I have the code block with "Active Storage in it. Maybe if you would share the .dyn and a test Excel / rvt file we could help you string it all together. I think you are very close.
@SeanP sure I can upload the dyn scripts tomorrow (Iāve left my laptop in the office) and the revit file is just a blank template with the sample arch file linked in. The spaces are then copied in using rushforth tools.
Ok so iām attaching a link to the blank spreadsheet template and the completed spreadsheet from the model export. The export script and the import script which obviously needs work before it can populate the space types!
I think I have resolved this for you. Please find the attached files for your use. The main reason your import graph wasnāt working was because you werenāt selecting the spaces to apply the Space Type too. CDL-Spaces Information Export.dyn (43.3 KB) CDL-Spaces Information Import.dyn (40.7 KB) Project1.rvt (3.6 MB)
I also assume there are spaces in the model? What results is the MEP node giving? Also, I donāt think you need Lacing on that node. Not sure I had that
