I am working on customizing the Write to Excel from Revit and then Read from Excel to Write into Revit. I want to be able to edit the Room Catergory Numbers is Excel and have them update the Revit model, but I keep getting the same error
Warning: Element.SetParameterByName operation failed.
The parameter’s storage type is not a number.
What am I doing wrong, thanks in advance!
@LeslieLinsmier Introduce a String from Object node between List.GetItemAtIndex and Element.SetParameterByName
create empty python node and paste:
OUT = [str(i) for i in IN[0]]
@LeslieLinsmier As the numbers are all integers you could try introducing Math.Floor or Math.Ceiling
Hope this conveys the idea…
Tomasz thanks your method and Vikram’s both worked…new to this but I find what you can create and manipulate is A M A Z I N G!!!
T H A N K Y O U B O T H
Leslie
