Importing Data from Excel into Revit
I am trying to import data back into revit from excel using the attached dynamo script?
I am getting an error and need help to try rectify it.
Hello @AndreaG_99 and welcome here, you will need feed in elements and be sure the list length match…
Hi @sovitek
I am still getting an error
be sure your list length match, and be sure that parameter is a text parameter as it looks like it a string you feed in the value.and probably set lacing to longest in setparameter…if it still doesnt work, you are welcome to share a sample dataset, you can upload with webtransfer, filetransfer etc. and upload the link here
