Import TINsurface and use polylines as boundries for creating 3D solids
I have a TINsurface and multiple closed polylines in my DWG. With the help of dynamo i want to create 3D solids from the TINsurface within the closed polylines. Can anybody help me
Hi @pim.sturm,
Your starting point will be these nodes:
From there, you should be able to use the nodes under Geometry > Solids > Solid to slice them up as needed using the polylines. For example, you could extrude the polylines as solids and then use Solid.Difference to get the overlap between the two.
Thank you for responding. I want to create solids with different depths.
@zachri.jensen @Anton_Huizinga here some more information.
In Civil3D 2025 i have some test geometry. A TINsurface for the elevation data. Some closed polylines that represent the new 2D design.
I want to create 3D solids with different depths inside the closed polylines. using the elevation of the TINsurface.
i found the solution by myself. the node i was missing is: geometry.IntersectAll
Thanks for the help @zachri.jensen
