I am working in the geotechnical department of a big company as CAD/BIM technician.
I got a lot of tasks regarding to generate solids between surfaces.
This year I got the opportunity to install Civil 3D 2021 + Dynamo so it feels that finally I should solve it.
I have found an interesting video here from your training:
I am new with dynamo, so I am learning, finding good examples to apply in my work.
I have tried to script your Dynamo’s nodes and also I have written the entire Python’s code (in the node Python Script).
I got an issue when I run the code:
File “”, line 37, in
ImportError: Cannot import name Messagebox
Do you know how I can solve it?
I have sent to you the .dyn via message. I hope you got it. Some images below:
Please check for the Civil3DToolkit package also from @Paolo_Emilio_Serra1 to install it in Dynamo.
There you will find the nodes to create solids from TIN surfaces.
My task is not to create a solid from a surface but I am going to create a solid between two surfaces, starting from a polyline as boundary.
The error now is:
File “”, line 232, in
File “”, line 205, in create_solids
StandardError: Cannot create a PolySurface from an empty list
@mzjensen that is amazing! I am on my way to office. As soon as I get to the office I try it.
I take the opportunity for questions.
The python script would make also possible to create a boundary (fo example a “close” polyline) and extrude only the surface’s portion delimited to the selected boundary. Is it still possible with this node? Is it “path” maybe?
PS of course I should cut the surface from Civil 3D but I am curious about it
Can I get the area & volume of the new generated solid between the two surfaces?
I haven’t tried the path, not sure if it works like this, but you can create a temporary surface by cropping the tin surface, using it to create the solids, and then delete it if you don’t need it :
