The first error is probably ‘the storagetype of the parameter is not a string’. That means you’re trying to feed a string into the parameter when you should actually be inputting something else (like an element maybe).
Check this post: Copy a number value from one paramter to another
Perhaps consider changing your language settings to english, it might be easier to look for an answer on the web. Not obligatory of course, just a suggestion.
