Ignore warnings when opening a Revit file
Hi everybody
Is there any node that can help me to ignore the warnings of a Revit file? I am trying to upgrade several files using dynamo, but if it finds a warning it stops the process. Is there any way to avoid this?
What is the warning you’re seeing?
using the Bulk Revit Rename upgrade, Revit stops when there is a warning, like dimensions deleted, relationship broken, link missing, family with errors… there are many reasons to stop, then bulk process is being interrupted … pretty much in every file there is a few stop points!
Did you guys found a node that ignored the warnings?
I wish there is a way to suppress the error message
There is a way to do this but not with a node - generally needs Python or zero touch nodes. Search the forums for IFailureProcessor - heaps of topics on it with solutions.
