Hi All,
I want to filter the walls by the thickness and name. So I have written this code in Python, i think the reason why its not working, is the fact that i combine two lists. Can somebody have a look and tell me what I am doing wrong and how it can be solved.
Tnx in advance,
Rasa
the second loop should start from 4 space from the first loop , like this :
for x in range …
____for i in range …
________if etc …
Thank u for replying. I saw that also and fixed it. still it does not work. I think that naam[x].contains(“werk”); _ is the problem
try changing and name[i].contains(“werk”): to:
and “werk” in name[i]:
Tom_James:
“werk” in name[i]
I don’t get an error, but it does not work. ides 8 should be true
I think it’s looping over too many times, try this instead:
OUT = [True if x>100 and x<200 and "werk" in i else False for x,i in zip(dikte,naam)]
try:
test=[]
for x,i in zip(dikte,naam):
if x>100 and x<200 and "werk" in i:
test.append(True)
test.append(False)`
OUT = test
Can you show the preview of the Element.GetParameterValueByName node?
Tnx, this works great. Could you explain why this one worked and what i did wrong?
Still trying to learn Python
