Filter a list with two conditions
Hi there,
I’m working on a script to filter a list of values with two conditions, but it doesn’t work. The list has values equal to 1 and -1, the idea is a script that returns True if the value is equal to them and false if it is different.
Can someone help me to find what is the error?
List = [0]
result = []
for i in List:
	if i == 1:
	 result.append(True)
	elif i ==-1:
	 result.append(True)
	 result.append(False)
OUT = result
script 2
@Joze Change the 1st line from
List = [0]
to
List =IN[0]
Not sure why you chose the Python route but using a code block would be much simpler!
I’m learning python therefore I tried to use it.
Thank you for your reply. :slightly_smiling_face:
Hello @AmolShah
Can you please show me your code inside the python script?
I added IN where you indicated but my code didn’t work. The other options work great!!
You need to use a tab after you’re if and else statement not a space.
I’ll try that. Thank you.
@Joze Try this:
List = IN[0]
result = []
for i in List:
	if i == 1:result.append(True)
	elif i ==-1:result.append(True)
	else:result.append(False)
OUT = result
Or using a tab instead of space as suggested (although it worked for me with the spaces)
Thank you :grin:
