Why do points appear at the endpoints of sketched lines when creating a floor?
I want to create a constant slope by changing the z-values at the start and end points of the floor.
Hi @jwchoiP67KQ
Please consult the community guidelines [ How to get help on the Dynamo forums ] as before the community can give you meaningful advice, we’d really need to see something you’ve actually tried.
Can you describe your intended workflow, and end outcome a bit more? It may be that Dynamo can assist with making it easier or there is a way to do this in native Revit, we just need a little more information.
Then you can share a graph, a screenshot, or even just describe the approach you’re planning to take node by node if Dynamo is the way to go.
The more effort you show upfront, the better the feedback you’ll get back, so post your efforts and you will find people here are very generous with their time. ![]()
