I want to a Add one more input Boolean(True/False) to the below python script, please helpout on these
clr.AddReference(‘System’)
Current doc/app/ui
app = uiapp.Application
Get revit version
revit_version = int(app.VersionNumber)
Define list/unwrap list functions
def tolist(input):
result = input if isinstance(input, list) else [input]
return result
def uwlist(input):
return UnwrapElement(result)
Preparing input from dynamo to revit
directoryPath = IN[0]
sheets = uwlist(IN[1])
fileNames = tolist(IN[2])
options = IN[3]
If we are in Revit 2022 or higher, print
if revit_version > 2021:
# Import the references
clr.AddReference(“RevitAPI”)
from Autodesk.Revit.DB import PDFExportOptions, ElementId, ExportPaperFormat
# Collect and set export options
opts = PDFExportOptions()
opts.HideCropBoundaries = options[0]
opts.HideScopeBoxes = options[1]
opts.HideReferencePlane = options[2]
opts.HideUnreferencedViewTags = options[3]
opts.MaskCoincidentLines = options[4]
# This will uses the Sheet Size for Paper size, or default to Letter
opts.PaperFormat = ExportPaperFormat.Default
# Variables to append to
results =
sheetList = ListElementId
# Execute the batch export
for s, n in zip(sheets, fileNames):
# Set file name
opts.FileName = n
# Add sheet to a list
sheetList.Add(s.Id)
# Export and append the result
result = doc.Export(directoryPath, sheetList, opts)
results.append(result)
sheetList.Clear()
# Preparing output to Dynamo
OUT = results, “SUCCESS: Version is 2022 or higher.”
Otherwise tell the user we can’t proceed
OUT = [False for s in sheets], “ERROR: Only works in Revit 2022 or higher.\n\nUse Revit.PrintToPdf node instead.”
![image|690x213](upload://iRcW0tYUaOBNU2YmVNDTGMecgXx.png)
what is holding you back in adding one more input?
Iam exporting both CAD & PDF , if i export CAD, pdf not exported so i need to add one more input of Boolean to the proceed that script or hold to play with true or false
Looks like you copied the contents of my print to pdf node in crumple and called it a day.
Need to show more effort to get assistance such as your script.
If you want to add more UI, look into data shapes package. If you want to add more Python functionality its time to learn Python I’d say - the forums aren’t chatGPT :wink:
Hi @GavinNicholls exactly same i copied your script, and iam trying to add boolean for Export pdf node.
Thank your very much @GavinNicholls your scripts helps a lot.
You could try a if node so you can control what to run
If they do this in Python they could do it in this manner.
@ramsaik495 go look at my add/remove revisions and there runMe input for an example of introducing conditional logic to running.
If you know Python this should be easy enough to emulate.
Thanks @sovitek i am applyed if node that’s works perfectly
yes @GavinNicholls i saw your scripts amazing more helpful, keep growing thanks a lot…,
