Dynamo python script in create sheets
Hi every one ,
I create script in python but every time i us it
create sheets but delete old sheet don’t keep old allows
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
from System import Array
clr.AddReference("RevitAPI")
app = uiapp.Application
#######OK NOW YOU CAN CODE########
ttb_d = IN[0]
nam_d = IN[1] if isinstance(IN[1], list) else [IN[1]]
num_d = IN[2] if isinstance(IN[2], list) else [IN[2]]
# Place your code below this line
sht_d = []
ttb_r = UnwrapElement(ttb_d).Id
for na,nu in zip(nam_d, num_d):
    sht = ViewSheet.Create(doc, ttb_r)
    sht.Name = na
    sht.SheetNumber = nu
    sht_d.append(sht.ToDSType(False))
OUT = sht_d
@amralhmady331
import sys
sys.path.append("C:\Program Files (x86)\IronPython 2.7\Lib")
import System
clr.AddReference("ProtoGeometry")
ttb_d = IN[0]
#Place your code below this line
sht_d = []
    sht.Name = na
OUT = sht_d
post your code this way…
KR
Andreas
Hi @amralhmady331, welcome
My understanding is that you are trying to create new sheets and your script it is overwriting existing sheets
You can add a check with the following code insert
# Collect all current sheet numbers
collector = (
    FilteredElementCollector(doc)
    .OfClass(ViewSheet)
    .WhereElementIsNotElementType()
    .ToElements()
sheetnumbers = set([viewsheet.SheetNumber for viewsheet in collector])
    # Check if number exists
    if nu in sheetnumbers:
        continue
    sht.Name = na
