Hi @Vinay im not really sure whats the issue is could you share your rvt sample…
Hi, here is a script with boolean management of contact with surface and orientation permutation (this should cover quite a few cases, until the next special case)
Thank you Mr. Sovitek for the compliment ![]()
Sincerely
christian.stan
reponse 27_01_21_beam for roofv2.dyn (36.2 KB)
Thank you so much @christian.stan, that is very helpful ![]()
Could you please guide me “Boolean and the code block next to eat”
Thanks @sovitek. it was something i wanted to automate.So for any arc or curve like structure i can automate framings ![]()
Great thanks, i see you have a great knowledge of design scripts.
I remember earlier i was working on to automate pile tags as pe my organisation standard in such a way that it tag all the piles from bottom left corner and sort 1st and them 2nd row and so on.
I failed in that but you quick response helped me bit to get a direction bu it was always picking “bottom right corner” and also an issue was that it somehow mis matched coordination values of a pile to other to tag. Which creates wrong coordinates values for piles.
I will let you know when i sort it out in near future.
Thanks ![]()
Hi @Vinay guess its a another topic…if Christians solution fit you please mark the solution, cheers ![]()
Yes @sovitek, Indeed
@sovitek, Could you please let me know which package you used for “Element.geometry Fast”
yes sure…synthezise toolkit
You will need install the package from packagemanager
Restored this post as it was required for the thread to read.
Thanks @sovitek. it worked
