I want dynamo file for make tunnel with dynamo segments
Hello seniors, I am completely new to Dynamo. I need some help. Can someone provide me with an easy method or a file? I need to create a tunnel using Dynamo. My requirement is as follows:
  • I need to create a 3D path curve.
  • Within that curve, I need to divide it into segments according to my specifications.
  • I want to be able to simply slide a number, and those segments should automatically apply to the curve.
  • Additionally, the components of my family (related to the tunnel) should also get applied on top of these segments.
Thank you!
@mrfurrukh
check out topics like this
Creation of the tunnel from the point cloud - Revit - Dynamo
You can use “BriMohareb_xxxx” and the below link to create your tunnel
This AU class may help you
autodesk.com
Automated Linear Structural BIM | Autodesk University
Building Information Modelling (BIM) for Linear Structures started to emerge in different markets. Through the last five years, this field has witnessed huge improvements either by individual personnel or by large engineering firms. Our firm –…
