I am creating a script that allows me to add a blueprint for each PDF in the specified path. However, I am not able to add the image of the PDF in the blueprint. Any problem with the ImageType instance and its arguments?
clr.AddReference("RevitAPI")
# Importar DocumentManager y TransactionManager
# Obtener el documento actual
rutas = IN[0]
caracteres = IN[1]
nGuiones = IN[2]
def create_plano(doc, nombre, r, i):
# Obtener la ubicación del centro de la hoja
center = XYZ(0, 0, 0)
# Crear una nueva hoja de vista
plano = ViewSheet.Create(doc, ElementId.InvalidElementId)
plano.SheetNumber = nombre
# Crear una nueva instancia de ImageTypeOptions para importar la imagen
image_type_options = ImageTypeOptions(r, True, ImageTypeSource.Import)
# Crear el ImageType en el documento activo
image_type = ImageType.Create(doc, image_type_options)
# Mover la imagen a la ubicación del centro de la hoja
imageInstance = ImageInstance.Create(doc, plano.Id, center, image_type.Id)
for r in rutas:
nombre = (r.rsplit("\\", 1))[1]
nombre = nombre[:len(nombre) - (caracteres + 4)]
if nombre.count("-") != nGuiones:
nombre = nombre[:len(nombre) - 3]
i=1
for i in range(20):
i +=1
try:
except:
break
Hello @oneiber_v and welcome !
try this version
# Import necessary libraries
# Get the current document
# Input variables
rutas = IN[0] # List of file paths (PDFs)
caracteres = IN[1] # Number of characters to remove from the file name
nGuiones = IN[2] # Number of hyphens to consider in the file name
# Start a transaction to make changes to the Revit document
# Function to create a sheet based on a PDF
def create_sheet_by_pdf(doc, nombre, file_path):
# Define a center point (XYZ)
# Create a new sheet in the document
plano.SheetNumber = nombre # Set the sheet number
# Define options for importing an image from a file
image_type_options = ImageTypeOptions(file_path, True, ImageTypeSource.Import)
# Create an image type using the specified options
# Define options for placing the image on the sheet
imgPlacementOpt = ImagePlacementOptions(center, BoxPlacement.Center)
# Create an image instance on the sheet using the image type and placement options
imageInstance = ImageInstance.Create(doc, plano, image_type.Id, imgPlacementOpt)
# Loop through each PDF file path in the list
for pdf_path in rutas:
# Extract the file name from the path
nombre = (pdf_path.rsplit("\\", 1))[1]
# Remove a specified number of characters and the file extension (".pdf")
# Check if the file name contains the expected number of hyphens
nombre = nombre[:len(nombre) - 3] # Remove the last 3 characters
# Call the create_sheet_by_pdf function to create a sheet for the PDF
create_sheet_by_pdf(doc, nombre, pdf_path)
# Complete the transaction
Note,
Errors should never pass silently, so this syntax should be avoided
try:
except:
break
Hello, thank you for replying. I have tried but I got the following error.
Advertencia
PythonEvaluator.Error en la operación
Evaluate.
File line 60, in
File “”, line 39, in
create_sheet_by_pdf
Exception: options.Path: unexpected
relative path or bad request to relativize a
path.
Parameter name: options
some problem with the path, it has only generated a plan for a single pdf of all specified in the path, also it does not add the image/pdf to the created plan. For some reason I always fail to insert the image/pdf to the plan.
I’m not unable to reproduce this error without more information
try to use this method to check if the path is correct (before to call create_plano
method)
