Import Image to view
I am trying to work throught the example from @Konrad_K_Sobon and the post http://dynamobim.org/forums/topic/is-it-possible/. I would like to place an image (digital image of professional registration seal) on each sheet.
However I am a bit lost as to the error message as I am pretty sure I have copied it steps exactly (sure u did, i know…)
“Warning: IronPythonEvaluator.EvaluateIronPythonScript operation failed.
File “”, line 34, in
AttributeError: ‘ImageType’ object has no attribute 'ToDSType”
Can u spot where I jacked this up?
<a class=“attachment”
href="//cdck-file-uploads-us1.s3.dualstack.us-west-2.amazonaws.com/flex022/uploads/dynamobim/original/2X/0/04ca7a9295965f31aae815201c538df1878efa33.dyn">ss.dyn (12.4 KB)
can you post the actual code? this forum is much better than old one and supports code so let’s not ask anyone willing to help you to retype that code.
Sorry Konrad,
Thank you so much for taking the time to post at all. Below is everything
#Import documentManager and TransactionManager
#Import RevitAPI
clr.AddReference("RevitAPI")
dataEnteringNode = IN
filePath = IN[0]
runIt = IN[1]
if runIt:
	tempName = filePath.split("\\")
	elementName = tempName[len(tempName)-1]
	imgs = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_RasterImages).WhereElementIsElementType().ToElements()
	for i in imgs:
		if i.ToDSType(True).Name == elementName:
			imageOut = i
			break
			continue
	imageOut.Reload()
	TransactionManager.Instance.TransactionTaskdone()
	message = "Success Bitches!"
	message = "Set RunIt to True."
OUT = message
See https://github.com/DynamoDS/Dynamo/issues/2460
Is your matter fixed now?
