I am trying to select boxes which are parallel to one another and close to each other. I want to lastly put them if in
How to select boxes which are in one direction, maybe parallel to one another and adjacent. I want to filter them want to put them in separate lists. Any ideas on how to approach this?
First group by their rotation.
  • Use a BoundingBox.ByMinimumVolume to get the box which is tightest to the original shape.
  • Use BoundingBox.ContextCoordinateSystem and a CoordinateSystem.XAxis node to get the vector of the X axis for the bounding box.
  • Use a Vector.AngleAboutAxis to get the angle to the canonical X axis about the cannonical Z axis
  • Use a Modulo (node looks like % for the name) of 90 to get the remainder of the angle after dividing by 90.
  • Finally use a List.GroupByKey to group the solids by the common angle.
Next up is finding those in a common group which touch. Watch the list levels and lacing closely here as you need to operate in the groups. Also if you won’t ever have a cuboid of rotation A in a group with rotation B you can skip everything above this.
  • Solid.ByUnion to convert each of the groups into one solid.
  • Solid.Separate to pull the individual solid parts from each group.
  • Geometry.DoesIntersect to test each of the original solids in the group against all of the parts in the group. Don’t operate at too high a level here or you will break things down. Read the primer and do the exercises on list levels and lacing if there are questions.
  • Finally use a List.FilterByBoolMask node to get the groups of solids which intersect with each of the separated parts of each union. This is your final result as you phrased the question.
Thank you so much for the detailed description. This helps a lot to understand. I am
Going to try this and get back to you.
The only point I’d like to add which I should have mentioned in my description is that, the boxes which are close to eachother are not touching. They are upside to have a 8 inches gap in between them from all sides. I am not sure if that will change the second part approach
Assuming it is a consistent 8” gap, use a Solid.ThinShell before the union. Interior dimension and exterior dimension can both be 8”. Join the list of thickened solids with the original by way of a List.Join, and then use the Solid.Union.
Hi @tabeertariq i guess "geometry.group,by.distance node from spring could work here as well…maybe :wink:
this step became very easy with your recommendation. Thank you
