Good Morning All,
I currently have a WIP PDF Renaming workflow that is correctly obtaining many of the required files to correctly name PDFs to BS 1192 Naming Convention. However, there are a few parameters that i’m struggling to obtain.
Below i have attached a snapshot of the current workflow.
The “List.Count” retrieves an input from another short workflow (View Sets, Get Views From View Set, Get built in parameter (with code block input as sheet_number).
The problematic “parts of the puzzle” are;
- the “project number” which i may need to get from “project information” category?
- the drawing type, i’ve set it as “DR” by default though it could be “SK” etc. Currently when i try to obtain “Type” it returns “sheet”. When i add a “watch” field it seems there are multiple “type” fields so maybe the easiest way forward for me is to change the name of the drawing “Type” parameter to “Drawing Type” so that it is easily identifiable.
- Suitability status. This i think may be the hardest information to retrieve as it’s based on a set of tick-box visibility parameters. See screenshot in following post.
On the far right of the main picture below, you can see within the “watch” box that the results are simplified into a list. I’m trying to stick with this same approach if possible as it’ll mean the rest of the workflow should still work
Many thanks in advance for any help!!!
Jack.
Your graph doesn’t show how you are getting the Sheet Numbers from your ViewSet sheets, but a couple of custom package nodes could help your graph to be more streamlined (pictured below Archi-lab and Beaker nodes)
Have also tried the List.Filter and List.FilterByBoolMask methods above to take only the list items that contain certain text but no luck.
you inspired me to check that my titleblock keyplans only highlighted a single building block, as below
