Hi folks - how is it going with the latest build that we have posted (0.7.2)?
I get issues with 2014. will test with 2015. seems that upgrade of dyn files is causing problems. I work with daily builds.
I was able to get a working Revit > Selection > Categories node, which I was not able to do in 0.7.1.
i have constant problems using code blocks
i.e.: Point.ByCoordinates(x,y,z) shows no result
Hi Peter,
I see https://github.com/DynamoDS/Dynamo/issues/2546, for this bug. Thanks.
Hello Peter Kompolschek,
I am able to use Point.ByCoordinates(0,0,0); in CBN and it is working on latest Release build which is 0.7.2
See attached image.
Thanks,
Ritesh
