how to use find and replace for project parameter value
can you try with method,
this is the concept i am given, you need to select the element as per your requirement, i am searching from comments, you need to do it for activity id , etc
ok i will try
need any dynamo packages?
Yes, its written on top of the nodes,
you need to download lunchBox and WombatDynamo
Hello @kaviyuvi0 …dont think you need custompackage for this task…
thnx i will try sir.
hi sir,
some error to my task, please resolve this error,
i think not parameter value (i need parameter text)
You are searching the content from empty list,
you need to give elements from which it will read the comments value.
Hi @kaviyuvi0 …yes do as @honeyjain619 show below or do as i showed in the image above…good luck
not working bro
please send dynamo file bro
replaceitem.dyn (15.8 KB)
HI Bro , I put my file drive link below. Please check
https://drive.google.com/file/d/1BDoZqnrqLsgvnbGjfGzc2m7Fv0JgyfJC/view?usp=sharing
thx bro
set parameter - Change the lacing - to longest
