Setting value for projectparameter
Hey,
I want to assign a value of 2500 to my newly created project parameter, but have no clue what to feed the element node of the element setparameterbyname node
Did you try to search on the(se) forums?
https://forum.dynamobim.com/search?q=get%20project%20information
Yes I did, but when you say it like that, the solution must be to simple. I want to set project parameters …not get.
https://forum.dynamobim.com/search?q=set%20project%20information
Changing the G to and S isn’t that hard :stuck_out_tongue_winking_eye:.
Although I did a search on the forums, your awnser did somehow help me to see that I’ve made an error. :wink: I fixed it and now it works…thanks.
AFAIK you could have used Text as Parameter Type, but then you had to type "2500" instead of 2500 in the Code Block for the value
