How to use Data.ExportExcel method in a python scipt
I was trying to use the Data.ExportExcel to write an excel file directly from a python script in Dynamo but I couldn’t use the method (the compiler said that Data is not defined). Should I import a specific library in my python script in order to use this function?
Hi @davidchivi,
The Node Data.ExportExcel is a Dynamo Node, you can’t use those nodes in a Python Script because they are written in another language/ they are not stand-alone functions.
I think it would be possible to create something similar through Python but you would have to access/ learn the Excel API to do this.
Also, why would you want to do this?
Nevertheless, this might help:
Thank you, I will give a look to your suggestion
@davidchivi It is possible! I just figured out how to do it:
Here is the python code:
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
from System import Array
from System.Collections.Generic import List as IList
clr.AddReference("RevitAPI")
app = uiapp.Application
clr.AddReference("DSOffice")
import DSOffice
from DSOffice import *
filePath = IN[0]
sheetName = IN[1]
startRow = IN[2]
startCol = IN[3]
data = IN[4]
overWrite = False
list = []
for l in list:
	list.append(Array[object](l))
list2 = Array[object](list)
list3 = Array[Array[object]](list2)
DSOffice.Data.ExportExcel(filePath, sheetName, startRow, startCol, list3, overWrite)
hello @leonard.moelders I was writting very similar script but I got a warning telling me the data is not an array[object]
regarding this issue I can see you created a definition of a list3 but I would change it like:
“for l in list:” as “for l in data:”
Oh yes. My bad. I will change that in my post :+1:
import sys
import System
import DSOffice
filePath = IN[0]
sheetName = IN[1]
startRow = IN[2]
startCol = IN[3]
data = IN[4]
overWrite = False
list = []
for l in data:
Could you help me… it doesn’t work for me and I get an error on line 49
Hi @AM3D.BIM.STUDIO
the method accept only a string for the sheetName parameter
so you need to implement a loop for multiple sheet Name, like this
or like this if you need to write different data by sheet
