I want to be able to write a dynamo script to detach the file from the Revit server and then archive on a network drive.
there is a nodes in Rythm, Orchide packages for open documents and save them, you can try by start with them
How do i get it to access the Revit Server when using the file path?
How can i get that path to look at the revit server?
Did you happen to figure this out @AustinMcCollum?
I can get it to work with the network drives on our network but can’t seem to figure out how to access the Revit server as my file path
Yes, I’m having the same problem…unsure how to access from the RSN.
