I am extruding a set of lines to a certain distance and if they hit an obstacle, the geometry, intersect will give you points of intersection. I eventually want to achieve making that red area by connecting all the points.
I’ve been having a problem getting a set of P1 and P2 lines for some reason.
I thought I could just trim the lines that are beyond the obstacle and just connect all the points - however, not as easy.
Any advice or help would be greatly appreciated.
Thank you for your time in advance.
You might be better off creating a surface and trimming that. It can be tricky to specify the order of points when creating an unknown polygon.
thank you Nick,
that would also make sense. Then do I make a surface by using P1s and P2s then use Geometry.Trim node to trim it?
Not sure how I would be able to make a surface with two lines of points.
thank you in advance.
I would create a rectangle. It’s hard to say what the best way would be in your situation since I don’t know how you’re getting those points to begin with, but there are many options.
thank you
which node is the most effective when I want to trim a surface with a curve?
I tried everything that I could find but no luck
You’re completely missing an input. You have to specify a point to determine which section to erase when trimming. Also be sure that your trimming curve is a singular curve or polycurve.
