How can I create a multi category schedule on revit through dynamo? the only node im finding is for a regular schedule with one input only for category
Follow as per below Image and filter by a category.
sorry I needed to specify better, I meant through dynamo
I’m not an expert on Dynamo yet, but did you try to make a list of categories in Dynamo as an input for that node you found with one input?
I thought there used to be a custom node in one of the common packages but I’m not seeing it now. You can do it through the API with Python.
use this in python for revit, maybe you can the solution try to solve your problem whit IA
Import the necessary libraries
clr.AddReference(‘RevitAPI’)
Get the active Revit document
Start a transaction to make changes to the Revit document
Create a blank schedule
id = ElementId.InvalidElementId
newSchedule = ViewSchedule.CreateSchedule(doc, id)
End the transaction to save the changes made
Return the created schedule object
OUT = newSchedule
