Schedule Parameters
Hello Dynamo friends :slight_smile:
I´m setting a bunch of schedule parameters successfuly. I can hide fileds, add filters, set formatting, grand totals, itemize every instance…
But i have some trouble with the following ones:
1) Set Text Type - Can´t get this archilab node to work, the python script is from the node.
2) Calculate Totals - found a python code here on the forum but it doesn´t work:
clr.AddReference(‘RevitAPI’)
from Revit.Elements import *
clr.ImportExtensions(Revit.GeometryReferences)
uiapp=DocumentManager.Instance.CurrentUIApplication
app = uiapp.Application
view = doc.ActiveView
def U(elem):
a = UnwrapElement(elem)
return a
schedule = UnwrapElement(IN[0])
colName = IN[1]
definit = schedule.Definition
countParameters = definit.GetFieldCount()
Parameter names
names =
for i in range(countParameters):
Parname = definit.GetField(i).ColumnHeading # Parameter Column name
if Parname == colName:
index = i
field = schedule.Definition.GetField(index) # schedule field
field.DisplayType = ScheduleFieldDisplayType.Totals
OUT = field
3) I´d like to hide the Schedule Title, can´t find any code for that.
Happy about any help :slight_smile:
i dont know what exactly you try, but the python template looks this way:
Can you discribe it better? count schedules?
Hey @Draxl_Andreas
I want to
  • Set Text Type
  • hide the title and
  • calculate totals
Which Revit do you use?
Could be your Revit API does not support schedule title.
Calculate Totals works now :slight_smile:
Only 2 problems left to solve.
#Import the Revit API
clr.AddReference("RevitAPI")
#Import the Revit Services
def U(elem):
	return a
colNum = IN[1]
field = schedule.Definition.GetField(colNum) # schedule field
OUT = field
I`m using 2021 and 2022, but the TextTypeId Property should work with all versions:
But I´m still getting that strange error when i try to set the texttype.
Hiding the title should also work with the API:
hello @gerhard.p
try this
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
toList = lambda x : x if hasattr(x, '__iter__') else [x]
lstviews = toList(UnwrapElement(IN[0]))
txtStyle = UnwrapElement(IN[1])
for v in lstviews:
	if v.ViewType == ViewType.Schedule:
		v_def = v.Definition
		v.BodyTextTypeId  = txtStyle.Id
		v.HeaderTextTypeId  = txtStyle.Id
		v.TitleTextTypeId = txtStyle.Id
		v_def.ShowTitle = False
		count = v_def.GetFieldCount()
		for i in range(count):
			field = v_def.GetField(i)
			if field.CanTotal():
OUT = lstviews
Amazing, thank you so much @c.poupin :smiley:
I added the following:
  • Don`t itemize every instance
  • Show grand totals
  • Grand totals title
import sys
import System
#import Revit API
for v in lstviews:
		#Set Text Type
		#Hide Title
		#Don´t itemize every instance
		v_def.IsItemized = False
		#Show grant totals
		v_def.ShowGrandTotal = True
		v_def.ShowGrandTotalTitle = True
		v_def.GrandTotalTitle = "SUMME"
OUT = lstviews
So the last step would be to activate the outline of the schedule, but i can´t find that in the API, i´m afraid i have to do that with the viewtemplate…
I believe this property is not exposed to the Revit API
Luckily this setting can be controlled with the viewtemplate :slight_smile:
