Revit Schedules - Add schedule filter w/ python
Hi All,
Looking for some help with python scripting.
I have a dynamo graph which aims to create a set of window schedules which will be filtered based on type mark. My steps are:
  1. duplicate existing schedule that is correctly formatted (minus filter rule to be applied). duplicate x number of times.
  2. get view names of duplicated schedules, and rename based on a list in excel file
  3. add filter rule to each schedule. the filter text is taken from the same excel file that has renamed the schedules.
I found the following in the revit api docs, however I’m still pretty new to dynamo/python and not sure how to put it together with the right syntax.
http://www.revitapidocs.com/2016/a5dfec9f-1efd-b507-d079-eabcbf5032f8.htm
graph attached,any help would be greatly appreciated!
edit: can’t attach the file, hopefully the link below works.
https://drive.google.com/file/d/0B4yQkxsIHY_NVVgycmVDZFVEVnc/view?usp=sharing
With some help from examining archi-lab schedule nodes, I’ve managed to get to a point where I can add a pre-defined filter in an existing schedule, and apply it to one new target schedule.
Can someone please explain how I might edit the script to take more than one schedules and more than one string value for each filter?
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
refschedule = UnwrapElement(IN[0])
tgtschedules = UnwrapElement(IN[1])
tgtstrings = IN[2]
refdefinition = refschedule.Definition
reffilter = refdefinition.GetFilter(0)
for tgtstring in tgtstrings
	tgtfilter = reffilter.SetValue(tgtstring)
for tgtschedule in tgtschedules:
	tgtdefinition = tgtschedule.Definition
	tgtdefinition.InsertFilter(reffilter, 0)
OUT = tgtschedules;
Figured it out. For anyone interested, script and dynamo graph below.
Schedule Filter.dyn (7.0 KB)
# Import RevitAPI
tgtstrings = IN[2]
tgtdefinitions = []
tgtfilters = []
a = refdefinition.GetFieldId(0)
b = reffilter.FilterType
	tgtdefinitions.append(tgtdefinition)
for tgtstring in tgtstrings:
	tgtfilter = ScheduleFilter(a, b, tgtstring)
	tgtfilters.append(tgtfilter)
for tgtdefinition, tgtfilter in zip(tgtdefinitions, tgtfilters):
	tgtdefinition.InsertFilter(tgtfilter,0)
OUT = len(tgtdefinitions);
Thanks for the tread it help me complete the task in the documentation package for assemblies.
https://www.youtube.com/watch?v=2NywSA6p99Q
Hi friends, I am new in dynamo. I need dynamo script for sheet creation along with view plans with help of excel sheet. Please anybody provide this script.
Thank You,
nice! let me get it with a large fry.
Thanks Andrew, the script help me solved my RLS schedule
