Hi everyrone,
Do you think setting cropbox views is a pain ?
You’re using the Python Node only ? Me too!
So here`s a script that will set the cropbox view visibility for floorplanviews and ceilingplanviews in your project.
You can adapt this script for other viewtypes
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import FilteredElementCollector, View, ViewType
views = FilteredElementCollector(doc).OfClass(View).ToElements()
for view in views:
if view.IsTemplate != True:
if view.ViewType == ViewType.CeilingPlan or view.ViewType == ViewType.FloorPlan:
view.CropBoxVisible = False
OUT = views
