Hi everyone,
I’m trying to get a crop box on a view, to select it in dynamo. I already try to use the code from Konrad K Sobon, but well… here is the message I had :
and here is the code :
clr.AddReference (‘RevitAPI’)
from Autodesk.Revit.DB import*
view = IN[0]
TransactionManager.Instance.ForceCloseTransaction()
tGroup = TransactionGroup(doc, "Temp to find crop box element")
tGroup.Start()
trans1 = Transaction(doc, "Temp to find crop box element")
trans1.Start()
view.CropBoxVisible = False
trans1.Commit()
shownElems = FilteredElementCollector(doc, view.Id).ToElementIds()
trans1.Start()
view.CropBoxVisible = True
trans1.Commit()
cropBoxElement = FilteredElementCollector(doc, view.Id).Excluding(shownElems).FirstElement()
tGroup.RollBack()
#Affectez la sortie à la variable OUT.
OUT = 0
Do you have any ideas? what is wrong?
Hi @mickael.g ,
Change “view = IN[0]” with view = UnwrapElement(IN[0])
#From Konrad Sobon
clr.AddReference("ProtoGeometry")
clr.AddReference ("RevitAPI")
tGroup.Start()
trans1.Start()
trans1.Commit()
trans1.Start()
trans1.Commit()
tGroup.RollBack()
OUT = cropBoxElement
thanks for your answer… I found a way to do this with existing node ^^ but I might need you help on another subject
Hi there !
I never used python before, but it seems that my problem has no other solution so… I begin with this program. End, of course, it doesn’t works.
clr.AddReference ('RevitAPI')
cropB…
