i am working with a graph that duplicates the views I selected as a dependent, then applies a scope box to the duplicated views. The last thing i would like to do is not working correctly though - set the crop region visible to NO. What am I doing wrong here? Cheers!
I read another topic quite similar to mine and that was the other person’s mistake indeed, so I tried to do the same. In my case it doesn’t work because the output I am trying to use is an array (perhaps because i used cross product ?)
views = UnwrapElement(IN[0])
for v in views:
v.CropBoxVisible = False
OUT = 0
I think the issue is the lacing and levels. I don’t know your exact dataset but using @L2 with cross-product even though both of the other inputs are only a single element may be messing you up.
Hello, I am trying to turn off my new Viewport Crop Region using with following script but it doesn’t work.
newViewport.LookupParameter(‘Crop Region Visible’).AsInteger().Set(0)
and also
newViewport.GetParameter(‘Crop Region Visible’)[0].AsInteger().Set(0)
Can anybody give me some help? Thanks
