please check flow chart. req. please correct me.
Hi guess Type gives an elementtype, comments expect a string try with element name after your getparameter
not sure, try with ootb element set.parameter by name
if that node is from wombat then it doesnt work if you are in 24, havent been upgraded
thank you , it is node issue, i tried with another node, its working.
