Hi everyone.
In Data-Shapes. How to save input value of Data-Shapes for the next time?
Thank you so much.
Hi everyone.
Thank you so much.
Write the value coming out of the UI++ node to a file saved somewhere commonly accessible (overwriting the previous values), and feed the default input with the results read from that file.
Thanks @jacob.small.
I did as your solution, but It doesn’t work. Please help me.
Where are you writing the file? Also if users are placing a comma between your entries a csv won’t work. Use a different format (perhaps txt) and a different separator (perhaps | or >).
Thanks you so much. Good job.
