Greeting.
I am working on the clash detection between wall and pipe. As you see below, there are 193 Pipes and 66 Walls in the project which generate 197 clashes point. The node I use is “curve.solidinstection”
The difficulty I met is I do not know how to return instersected curve is come from which original curve?
This is because I would like to get every individual pipe size from clashed point. It seems (or I dont know the way) to return the correspond curve to find the pipe size.
It would be great if you can help me. Thanks!
