HI I want to remove these items from the list but I cant with boolmask or comper or…any one can show me the solution?
NOT according with index please
Can you explain the logic behind excluding indicies 3,4 and 5? I don’t quite understand what you’re after here.
Same topic twice?
https://forum.dynamobim.com/t/separate-the-repeated-item/89551
i mean i dont want use of index…same as ITEM OF INDEX
it was according to index
But 0 and 180 are not the same…
Ah! You’re looking to get angles which are orthogonal to the base direction.
I’d use the modulo function here instead of defining a list as it will provide more consistent results.
n%90 == 0 in a code block, or % node followed by a == node.
