I am new to use Dynamo in Revit. I have been adding and deleting many Custom Nodes. When I add a new Custom Node, I always specify “Revit” as the “Category” for the new Custom Node. The result is that I have many Custom Nodes under “Revit” in Add-ons area of Dynamo. I have already removed the actual Dynamo definition files of half of my Custom Nodes. But they still show up under “Revit” in Add-ons.
Please let me know how to remove them from Add-ons area. Thanks.
Somehow the unwanted Custom Nodes have disappeared from the Add-ons area in Dynamo despite the fact that they are still in the backup folder. I am not exactly sure what caused them to go away. But the last thing that I did was removing all the unwanted entries from RecentFiles section in the DynamoSettings.xml file that is in this folder:
I don’t see how removing the entries from the RecentFiles section of the XML file can also remove the unwanted entries from Add-ons. Therefore, this may not be it.
The second from the last thing that I did was to remove all the script/definition files away from the original folder, and to move those that I want to keep in a new folder, and then I changed the path in “Manage Node and Package Paths” to the new folder. This “may” be the trigger that caused Dynamo to remove those unwanted entries from Add-ons area. Not sure.
OK. I did some more test, and I am sure that the solution has nothing to do with removing entries from RecentFiles section of the XML file.
Unfortunately I still cannot figure out how the problem started and how it went away. I have a vague feeling that the problem might be triggered if the unwanted script was stored in a folder that is not in “Manage Node and Package Paths”. But I cannot trigger that error on demand. Therefore, I am not sure.
I have a feeling that the unwanted entries were removed when I remove all the script/definition files away from the original folder, and to move those that I want to keep in a new folder, and then I changed the path in “Manage Node and Package Paths” to the new folder. This “may” trigger Dynamo to remove those unwanted entries from Add-ons area.
