How to read out a level from a curtain wall panel
I am trying to create a script to read out the levels of curtain wall panels.
Currently, I have a filter that reads the curtain wall panels connected to an Element.Geometry-node.
Could someone explain to me how best to proceed now to read out the levels? Do I need to connect the curtain wall panels to the right curtain walls?
Welcome to the forum.
How would you go about finding that information in Revit? Dynamo requires the same logic as Revit (it’s the same process), so it’s always best to start by understanding your workflow through Revit. Do the panels have a parameter for Level? Do the associated walls have the parameter?
I have added a shared parameter ‘BaseLevel’ in the model, this instance parameter relates to the curtain panels and the walls. Can I look for the host of the panels so that the Base Constraint of the walls can be read in the panels?
Hi @jelle.vandoninckS4TV and welcome :wink: sounds like the right way to go :wink: maybe as here
Thank you very much! :grinning:
Can you tell me which packages you have used?
yeah sure…genius loci and for check for curtainwalls is spring…
