Hi everyone, i want to duplicate views and place on sheet. Everything is ok when i duplicate view, and then i place sheet on view with View.Sheet node, but i have problem with type of view is Structural plan view and schedule view. How i can place all view on sheet ?? May i use python code for it ?? This is my file dynamo, someone can check it for me, thanks for reading.
using this node will create the sheet and then place the view…i have tried this every time it will create the sheet…there no node to place the view after create the sheet…
thanks for you answering, but Are you try use Node Sheet.ByNameNumberTitleBlockAndViews to place views with type Structural plan view and Schedule view ?? My file dynamo is ok with Plan view, Drafting view, Legend, Section, Elevation View, but it has problem with Structural View and Schedule view.
Someone can test Node Sheet.ByNameNumberTitleBlockAndViews and will see, i’m sure 100% it has problem with these view style.
