How to Place Annotation Texts at Specific Coordinates in a Revit View Using Dynamo Chiedi a ChatGPT
I’m working on placing annotation texts in a Revit view using Dynamo. I have a list of texts and their corresponding X and Y coordinates, and I want to position these texts accurately in a specific view.
Could you please help me understand the best way to create and place these annotation texts at the given coordinates within the desired view?
Thank you in advance for your assistance!
from RevitServices.Persistence import DocumentManager f
rom RevitServices.Transactions import TransactionManager
clr.AddReference(“RevitAPI”) from Autodesk.Revit.DB import *
texts_pilastri = IN[0]
x_pilastri = IN[1]
y_pilastri = IN[2]
texts_muri = IN[3]
x_muri = IN[4]
y_muri = IN[5]
view_input = IN[6]
if not isinstance(view_input, View): OUT = “Errore: IN[6] non è una vista valida”
view = view_input
created_notes =
def create_texts(texts, xs, ys):
result =
for i in range(len(texts)):
try:
pt = XYZ(float(xs[i]), float(ys[i]), 0)
note = TextNote.Create(doc, view.Id, pt, str(texts[i]), TextNoteType.GetDefaultTextNoteTypeId(doc))
result.append(note)
except: result.append(None) return result
created_notes += create_texts(texts_pilastri, x_pilastri, y_pilastri) created_notes += create_texts(texts_muri, x_muri, y_muri)
OUT = created_notes
Hi, @gabriele.potenza1
  • Format your code with the </> button
  • Add screenshots of your dynamo graph and the error
  • Read this documentation about DynamoPython and wrapping of Revit objets
I solved by using TextNote.ByLocation. I forgot its existence. Thank you!
