Create text/comment on element using dynamo auromatically
Hello everyone, i’m curious how to make text/comment at element family based on instance parameter value in each spesific point that can be seen in 3D view automatically like the illustration on image below ?
Thanks in advance, i’m very apprecite for your answer or ideas
Hello @yusufarifin here is a fast example there probably could work if you are in project
PS. text node is from Dynamotext package
Revit_0uIOoegigN
Assuming you can lock the view or the annotation type you use supports 3d view in any orientation, a tag gets the job done if this is already a revit element.
Yeah…can probably work as well, depends what user is after…i guesss :wink: ;
Woah that’s interesting! i will analyze that first, thanks for the idea
