Translated by moderators. Original text below the line.
How is the face-based family placed on the wall, and the subject of the family is the wall, the family can also adjust its elevation
Original Post
请问基于面的族如何放置在墙上,而且族的主体是墙体,族还可以调整其标高
Original Post
@11074533, the forum language is English. This is a requirement for search feature to work. Please translate all posts using a basic web translation as I did in your post in the future. It takes a lot less time for you to do this than it does me to edit it. Thanks!
Also, we need a bit more info here to understand what you are after. This post could help you understand what we need: How to get help on the Dynamo forums
Can you give some basic files to test with, including a Revit file, the Dynamo graph which you currently have, and any sketches or other info which explains what you are after?
Hello, this is my Revit file and Dynamo file. At present, the main body of my socket is not a wall and the height cannot be adjusted. Do you have any good methods to change the main body of my socket to a wall and the deviation value of the height can be modified? 0DBDFD61C7A}
Looks like the file failed to attach.
Hello, as I am a new user, I cannot upload the attachment. Could you please give me your email address?I’ll send it to you.
Ah. I made a quick correction to your account so you should be able to attach now. If not try a service like google drive, box, onedrive, or the like.
Looks like it but I won’t be able to open for awhile as I am on my mobile at the moment.
Can you change the body of the socket family to a wall? Can the elevation be modified?
original post
请问可以把插座族的主体改为墙体吗?标高可以修改吗?
Forgive me for replying to you in Chinese. It can be achieved.
original post
原谅我用中文回复你 可以实现
Hello @891922347 The forum is still in english, please translate your post as Jacob mention in post #2
