Is it possible to move/translate elements with Dynamo? I need this for rebars.
The only way I know is to copy and delete but I need to move existing reinforcement.
Hello @Konrad_X-PLAN …you could try something here…
I am pretty sure that it didn’t work for rebars in the past
Where can I find “Element SetLocation”? (on the right)
Genius Loci
Move by vector works for unhosted elements usually. It will need a start/end transaction node to be used before/after the node as well I think.
@Konrad_X-PLAN Do you know where to find “Element.MoveByVector” node?
This is a standard node in Dynamo for Revit.
Found it. Thanks
