How to merge all? Point at element and his room
my script worked well … how to merge all steps? in Python
HasCalculationPoint → RoomAtPoint → Roomname ?
…does this work for any Point ?
HasRoom.dyn (20.6 KB)
clr.AddReference('RevitAPI')
clr.AddReference('System')
def toList(x):
	if hasattr(x,"__iter__"): return x
	else: return [x]
elements = UnwrapElement(toList(IN[0]))
output = []
for i in elements:
	output.append(i.HasSpatialElementCalculationPoint)
OUT = output
def GetLocation(item):
	# if it has a calculation point return that
	if item.HasSpatialElementCalculationPoint : return item.GetSpatialElementCalculationPoint().ToPoint()
	# if not return the regular location
	elif item.Location.GetType().ToString().Contains("LocationPoint") : return item.Location.Point.ToPoint()
	else: return None
items = UnwrapElement(IN[0])
if isinstance(IN[0], list): OUT = [GetLocation(x) for x in items]
else: OUT = GetLocation(items)
points = IN[0]
output = []
for i in points:
	if doc.GetRoomAtPoint(i.ToXyz()) == None:
		output.append("No Room")
		output.append(doc.GetRoomAtPoint(i.ToXyz()))
OUT = output
KR
Andreas
I don’t see any reason why you shouldn’t be able to put everything into one python script. You could even collect all elements from the category “Allgemeines Modell” ↔ “OST_GenericModel” via python.
