Hi everyone!
I tried get “name” and “area” of FromRoom but result don’t correct.
“Room Name” contain room number and “Area” not round all element.
Please show me where is incorrect code.
Thank Advance!
doc = __revit__.ActiveUIDocument.Document
uidoc = __revit__.ActiveUIDocument
def get_from_room_name(element):
try:
return Autodesk.Revit.DB.Element.Name.__get__(element.FromRoom[phase])
except:
return None
def get_from_room_area(element):
return round(((element.FromRoom[phase].Area)*0.092903),2)
phases = doc.Phases
phase = phases[phases.Size - 1]
#Select all elements category from revit
selection = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Doors).WhereElementIsNotElementType().ToElements()
#get From_Room_Name
room_name = []
for i in selection:
room_name.append(get_from_room_name(i))
for i in room_name:
print(i)
#get From_Room_Area
room_area = []
for i in selection:
room_area.append(get_from_room_area(i))
print(room_area)
@manhgt214 ,
check out this topic
builtinparameters easy to catch, in general
keep attetion to your syntex, “print” want work … use the template from primier!
import sys
clr.AddReference('RevitAPI')
clr.AddReference('System')
try:
return Autodesk.Revit.DB.Element.Name.get(element.FromRoom[phase])
except:
return None
phases = doc.Phases
#get From_Room_Name
room_name = []
for i in selection:
#get From_Room_Area
room_area = []
for i in selection:
OUT = room_name, room_area
